I noticed on my Balance 20X that if I disable Remote User Access, and then re-enable it, the settings are all lost including which type of VPN one previously had. (Network → Remote User Access) That’s pretty annoying. I would prefer the settings to be retained so one could just toggle Remote User Access with the enable check box. So my feature request is to change the behavior of this setting to retain the type & credentials when disabled.
