Dear Guys ,
I see some features in Peplink Balance user manual 6.1 which I can’t find them on Peplink Balance 710 Demo Device on your site !
for example : operating schedule , power boost , output power , etc.
Thanks - Hootan
Dear Guys ,
Thanks - Hootan
Dear Lai ,
It was a trick ! I should search all Question marks from now on to find advance features Thanks for your note.
Could you please tell me what “Client Load Balancing” feature exactly do ? not mentioned in user manual.
Thanks - Hootan
Hi Hootan,
Below is the usage of “Client Load Balancing”
Example of Setup:-
When “Client Load Balancing” is enable and a new user is trying to associate with AP2, WLAN controller will redirect the user to AP1 since AP2 has more connected clients. Thus, client load balancing can be achieve.
Great , Thanks for useful information provided.
I need to know about “Dynamic Output Power Control” also and how it works.
Thanks - Hootan
Hi Hootan,
Do you mean Output Power under the AP Profile?
Yes , right.
Hi Hootan,
For Dynamic Output Power, Controller will check the RSSI of the neighbor APs (within the same profile) and adjust the power accordingly. There are 2 different options, “Auto” will check periodically while “Manual” will only be triggered by clicking “Trigger” button under “AP -> Toolbox -> Auto Power Adj.”
Great , Thanks for useful information.
Hootan
Sorry to resurrect this old thread, but I don’t see the Output Power = “Auto” option on either the AP Controller on my Balance One Core, nor on InControl2… Both only list Max, High, Mid and Low as options for Output Power.
Output Power “Auto” option is not available for AP Controller standard version.
For more information, please refer to the attached screenshots below:
AP Controller Standard:
AP Controller Pro:
Please also refer to the URL below for the device model that support AP Controller standard vs AP Controller Pro:
Thank You
Sitloongs, thanks for your reply.
I suppose AP Controller “Standard” is not software upgradable to “Pro”, so what about InControl2 ? Any chance that it will ever support Output Power = “Auto” ?
Output Power = “Auto” only supported on Balance 305 and above. Please consider this if this feature is needed.
Thank you.
@sitloongs or @TK_Liew what about the Balance 310X? I don’t see the Dynamic option for Power although it appears to have AP Controller Pro.
In this image, the 20X and the 310X are the only ones that are marked with what I thought was the indicator for AP Controller Pro. In addition the 310X has the “Full” Web Filtering Blacklist. This indicates that the 310X matches the table for the “Models for Enterprise / Headquarters” in feature support.
The 380X and 580X have this footnote in their feature table. What am I missing that at least the 310X should not come with AP Controller Pro?
^ Balance 380X/580X comes with AP Controller Pro, which supports multiple configuration profiles with multiple SSIDs, and you can manage remote APs outside the local physical LAN.
