Hello, i have looked through your products and i’m a bit confused about what i need. I have a solar home system which contains of a 80W solar panel and a 55Ah battery, which uses 12V DC. Do you have any wifi that can operate on this system or do i need a inverter?
Welcome to the forum!
Do you need just wifi or a router to connect to the internet?
Quiet a few of our products can run directly of 12V DC. Below are some of them;
Wifi;
- AP One AC Mini
- AP One AX
- AP One Rugged
- AP Pro AC
- Ap Pro Duo
Routers (with wifi built in);
- BR1
- Transit
- UBR-LTE
- HD2
- HD4
- MBX
- Balance 20X
- Balance One
- Balance 30 Pro
SD-Switches (must be powered by 48V DC fro PoE to function);
- 8 Port Rugged
-16 Port Rugged - 24 Port Rugged
This topic was automatically closed 182 days after the last reply. New replies are no longer allowed.
