- What is the Wifi coverage distance/range for MAX HD2/4?
- Can it cover distance about 60 meter, at open area with tall trees in between?
Thanks. CY
Thanks. CY
Hi cernyeing,
welcome to the Forum!
the coverage is depending of many factors like in your case humidity, the amount of trees an their distance and other noisy signals.
60m could be a really big distance for WiFi. Have a look at the Outdoor-WiFi-Accesspoints an the Device Connector. This could help you, I think
Regards
Dennis
