I have the Pepwave Surf On-The-Go and an AT&T Unite Mi-Fi hotspot. The hotspot is a Netgear AirCard 781S Mobile Hotspot.
I have connected via Wi-Fi. It doesn’t look like this unit is supported for direct USB connection from what I can see.
1.Is there any advantage to connecting directly via USB or will the performance be equal using the Wi-Fi setting?
In the AP settings should I use the same password as the Mi-Fi?
