What security camera system works with a mobile router with low speeds
max transit duo with Verizon data plan. Blink camera system will not work on it. only had 3mbps on upload. Blink nor mobilemusthave could not solve the issue. Looking for suggestion on something that is known to work.
3mbps is plenty for most. Including Google, ring, etc. I think on high quality Google I see an average of 1mbps. . Most publish this
Look for one that doesn’t store video streams in the cloud, but stores video on a sdcard, depending on use case and if that will work - that will use a tons less mobile data.
3Mb/s should be plenty. I have 4 Google Nest cameras using a connection (wired) with a 5Mb/s uplink, they don’t tend to use more than about 2Mb/s in total (for all 4 cameras).
The Google Nest cameras have a slider control how much bandwidth it uses. “High” says it uses 400GB/moth (1.2Mb/s), “Low” is says 100GB/moth, and it doesn’t even use that much, one set to high used 200GB last month, others only 100GB.
