Just acquired a pepwave transit duo in great shape, but I didn’t receive a power cord. Is there a standard USB cord that will connect to it? If not, where can I source a replacement power adapter (ideally for USB / 12V purposes). Thanks!
You can use any of the following;
Micro USB supplying 5V, 2A
DC Input 12 - 48V DC, 2A (on the terminal block or barrel socket)
Hi Sam,
is it possible to power the MAX Transit with the SD-PMU? The output there is 52V and the max Input on the Tranist is 48V…
Dennis
