Pepwave Surf SOHO Firmware: 6.3.2 build 2158
When I do network -> network settings, I see a list of my defined VLANs. The last column in the list is an X. Most VLANs have a red X, one is gray. What’s the difference?
When I hover the mouse over the gray X it says “In used by port settings”
The VLAN with the gray X is assigned to an Ethernet port, the others are WiFi and untagged. I checked the Pepwave MAX and Surf User Manual from Aug 2016, but couldn’t find an answer there. Thanks.
