Wfi signal not broadcast
I disconnect my Max Transit LTEA for a few days and when I powered it up again there is no wifi signal broadcast. Status lights look correct and I can log in from home using Incontrol. The broadcast SSID box is checked. What could be wrong?
Please try to disable and enable the service.
@eprmang ,
May I know the firmware running for your device ? We do have similar issue report for the deivce that running firmware 8.2.0 that should be fixed in firmware 8.2.1.
If you are using firmware 8.2.1 but still see the issue , please open a support ticket for support team to check on that.
