Hi Forum, need your help:
I have 2 DSL & 1 Cable modems, all in DHCP mode. Each provide about 20Mx10M on good days.
I have 30 Axis webcams for our company, which connect to a remote server to then make viewable on our website.
I have 3 Netgear consumer routers (192.168.10.1, 192.168.20.1, 192.168.30.1) which I use to help spread out the bandwidth and allow for employees to also use the net.
All 3 routers go to a 24 port unmanaged Netgear switch which goes to the cams and wired connections for company computers.
QUESTIONS FOR THE FORUM:
To make these Axis webcams work, Netgear consumer routers use “port forwarding”. I have to give each camera a static IP, and then assign ports. However, I’m not clear as to the best way to do this with Peplink. What section of the GUI controls this?
I want the Peplink to replace all of my consumer routers. Is this possible? Is it a good idea? Or should I only use Peplink to do smart load balancing?
Does Peplink do Parental Controls like Netgear consumer routers? Where is this located?
