Web Blocking
We have made some configuration using the web blocking function but when I set locked pages the BR1 does not make the changes and continue browsing?
This happens for http and https urls.
Another related question, How do I can set the wildcards?
For example: .youtube. in order to block:
youtube.com.mx
Hi Joel,
Please take note Web Blocking only blocks Http URL.
Can you share which URL you try to block but not successful?
Hi Joel,
You may apply your wildcard like this - youtube.*
Hi TK Liew,
When I try to save an URL using a wildcard, I receive the following error:
Here is the firmware version:
Hi Joel,
This is known issue on v6.1.2 and was rectified in v6.2 GA. v6.2 GA to be available in Q1 2015.
You may try v6.2b03 if needed. The fixed already there.
