Hi, Sorry Newbie alert !! Is it possible to access web admin via WAN connection after enabling IP PASS THROUGH on cellular? . If not is there a work around? Thank you for your help.
After enable IP Passthrough, you cannot access the BR1 Web Admin from Internet. Anyway you can use InControl2’s Remote Web Admin to access BR1.
Thank you for your quick response. If the device will be on a private network how would I reach it via InControl2? Will I be able to stream GPS data stream ?
Regards
If the device is registered to IC2 it will report information/sync with IC2. Even if the WAN IP of the unit is private you will be able to remote in via IC2 website. Yes you will be able to stream GPS data.
