I have been using the Pepwave Max BR1 MK2 for two weeks and doing great. Then yesterday the internet speed dropped to .5 mbps.
Thought it was the cellular so switched SIMs. Same issue. (Bars are great) And the admin site takes forever to load. I’ve tried restarting many times and also updated the firmware. When the admin site freezes it displays this error: Unable to reach web admin. Connecting in 30s.
Hi Nat,
I would suggest a full hard reset first (paper clip held in the reset button hole on the front for a slow 10 count). Then check the power - are you using the AC mains adapter or are you on a vehicle battery?
If that doesn’t clear it grab a diagnostic when you can and log a ticket with Peplink Engineering.
It’s working now. Not sure why. Does the power source effect performance? The problems started after we’d be using our RV batteries for a couple days and they ran out of juice. It is a 12V to AC inverter system. Now that we’re plugged in at a campsite, it’s been fine.
Also, seems like there’s a hardware issue with the reset button.
Just wanted to call out that I’ve been experiencing the same issues starting about a week ago. I have a Pepwave Max Transit Cat 18 and every day the connection becomes unusable and the admin web interface slows to a crawl. Manually rebooting the device clears the problem for another day. There’s nothing wrong with the upstream data connections - using both cellular and 5G wifi and both are solid. Saw that there was a firmware upgrade so just upgraded to 8.1.2 this morning hoping that it may help. Not sure what else to do.
This is a very long shot: We had similar behavior on a BR1 Mini LTE-A. It turned out to be a dysfunctional Wi-Fi antenna. Replacing the antenna fixed the problem. (It is the first time I’ve had an antenna go bad on me).
