Good morning. I just have a question if other people have/are experiencing this issue. It’s mostly a cosmetic issue but it bothers me.
Balance One Core: firmware 7.1.0 build 3433
WatchGuard XTM515: Fireware OS v12.1.B548280
I have 4 point-to-point IKEv2 IPsec VPNs setup from a small office (Balance One) to several larger offices (WatchGuards). For some reason the web admin dashboard (and under IPsec VPN status) on the Balance One Core will occasionally show the both primary and secondary connections as down even though they’re not. Things continue to work properly and the WatchGuards show the connection as up. This usually happens after a hiccup in the line which causes the VPN to failover to a different WAN or recover from a failover. Has anyone else seen this?
To fix the issue I have to disable the VPN via Network > VPN > IPsec VPN > IPsec VPN Profile and then reenable it.
Thanks in advance!
