Getting a new fiber connection and am getting a different IP setup than my current two WANs. This time around, it is a bit more “traditional” and the ISP is assigning me a /30 for the point to point connection to them and then giving me a /27 from a totally different block to assign to my clients.
While I have set this up on a Mikrotik in the past, I have not done non-continuous blocks of IPs on a Peplink. While I get the /30 - that is a simple static IP setting for that WAN port, can I simply add the /27 IPs to the list of Additional Public IP Addresses even though they are not in the same block as the /30?
Thanks. Assuming I need to leave out the NETWORK IP of the /27 as assignable, right? If I am assigned 10.10.10.32 - 10.10.10.63 as my /27, I enter the .32 as the “IP Address” with a /27 subnet in the Peplink or use .33 as the “IP Address” with a /27 subnet? Does Peplink take the first address entered in that list and make it the “network” or since it is NAT mode, I don’t need to define a network…
