WAN quality reports do not show Signal levels information for 5G connections. You can only see the latency. Is there something I’m not seeing or is this a known issue?
Thanks and regards,
Nacho
Thanks and regards,
Nacho
A known issue.
It will be available in the upcoming release of InControl 2.9.1 I understand.
great, thanks for your reply Martin.
I saw there been an update on this. We are now able to see the different bands and we can toggle them on/off to make the graph more readable. This looks really good!
Just one minor thing I saw on the details popup box when hovering on the graph, values are correct but not the titles. It should say Strength (RSRP), Quality (SINR), Quality (RSRQ).
Hi Nacho,
It has been fixed, please check.
Poyi
Yes, perfect!
