I need the ability to set my health check on my cellular WAN connection so when it does a ping test that it also confirms that the latency is less or greater than a number I specify.
Just because I can get a response on the the ping does it mean that connection has a strong enough signal to handle my needs. It may be that I want to disable that WAN if the latency is greater than say 100ms. It seems like an easy condition to add as an option to the PING test since that information is natively returned by almost all ICMP commands. If similar conditions could be added to other health checks I think that would be valuable as well.
My device is a Pepwave Max700
