Hello friends.
I need help with network policy.
I run a VOIP server to get to it and I have no problem, but because I have several IP addresses there is a status that the exit is coming from another address.
How do I set port and login from the same WAN connection?
You can configure outbound policy rules under: Network> Outbound Policy to determine which WAN link to use for your VoIP server.
It’s really frustrating because I can not make it.
Is there a guide with pictures attached to the subject?
Thanks a lot DON, I’ll try it
