WAN 3 dns problem
hello support
one of client bought a balance 30 and one month old the problem is wont resolved DNS even static or dynamic, could be a bug??
thanks
If you set the health check to use 8.8.8.8 and 8.8.4.4 for the dns check does the wan pass the heath check?
If so then using a PC can you query DNS on 192.168.254.254 address?
On windows you could go to cmd > nslookup > server 192.168.254.254 > www.google.com
If it works then you should get a response like:
Non-authoritative answer:
Addresses: 2a00:1450:4009:80a::2004
172.217.23.36
hello
if i use 255.255 it same problem now im confuse because in WAN2 using 255.255 / 8.8 works fine
I would suggest raising a ticket so that we can take a closer look at the device. Could you email [email protected] including a description of the issue, the serial number of the device and a diagnostic file please.
you can get the diagnostic by going to the status page and choosing to download the diagnostic.
hello it works now thanks
