If you have a Balance 210 on both sides then you can create a SpeedFusion VPN tunnel that will not break if one of the WANs fail. If you only have the 210 on the branch side then you would need to create an IPSec tunnel over a single WAN connection and the tunnel will break if that WAN goes down.
