We are trying to create a IPSEC connection with a draytek 2920.
We get the following error:No acceptable response, please verify the settings.
Can someone assist us?
Peplink:-
Please consult your vendor on IPSec settings for draytek 2920.
Thanks for the reply. We bought 3 pepwave max br1 4g routers and are in the process to buy more, we just need to know they work with watchguard. Draytek was just a test. Do you got any examples how to make a pepwave work with a watchguard? It looks like we are having problems with the remote id, cause its not a static ip cause of the 4g provider.
Justin
Thanks, I tried the settings but still not working.
Pepwave settings:
Am i missing something?
Note: the pepwave is on a 4g connection, but that wouldnt be a problem would it?
Its working now!
The tunnel goed up, and its connected, but neither of the machines behind the watchguard/pepwave can ping/reach eachother. Am I missing something in the Pepwave?
Do we need to enable NAT-T?
As you said the MAX BR1 is using 4G as WAN connection, I expect it’s using private IP and behind NAT. So your guess is probably correct, yes, please enable NAT-Traversal on IPsec VPN settings page (on top of the IPsec VPN Profiles) and try again. Thank you.
Hi Justvd,
I was wondering if you’ve had success with turning on the NAT-T setting and if that fixed the end-to-end ping once enabled? It would be valuable information for the community.
Taylor
