VPN and streaming to Brightcove
I am looking at buying some of your products. I will use 4g cards and send the bonded signal to our HQ through a VPN and then I would like to send the signal to our service provider for live streaming. What would the be the best solution and how could I achieve the best result?
Thank you very much,
Regards,
Erik
Hi Erik,
You will want to use the MAX 700 paired with a Balance 210 or higher at HQ to create the SpeedFusion bonded VPN tunnel, this will be ideal.
Regards,
Tim
Thanks Tim,
So I would bond the signal back at the office and then send it to Brightcove or an Akamai service. What would the configuration of this scenario be?
In the settings of the two devices.
Cheers,
The SpeedFusion VPN tunnel is super easy to configure, have a look at this KB article:
