I have a small problem with connecting to printers via VPN.
I am trying to connect a laptop through WIFI, to a VPN on the Balance 30 device.
But even after I plugged in I can not see the printer on the network.
Where am I wrong?
I’ve attached a chart for clarification31.pdf (462.5 KB)
You’ve got a couple things going on with this. First off the WAN and the LAN should not be in the same subnet and the other thing is that you are connecting directly to the modem itself which is a WAN connection.
You should put that modem in bridge mode as well and then put an AP on the LAN side for the Wi-Fi.
