VLAN not working
I configured a new switch today which is directly connected to the peplink router.
On another location I have a similar setup (peplink router + switch) where there is no issue.
Router has 3 VLANS
1 default untagged
2 vlan for operational technology
3 for management of VSAT equipment
Switch knows VLAN 1 & 2, and is set up with fixed ip for VLAN2.
From router I should be able to ping the switch on VLAN2 ip but it is not (it is on the other location).
Router has DHCP enabled for VLAN 2.
All ports on router and switch are configured as trunk allowing all VLAN (idea is to limit 1 port on switch to VLAN2)
Since the configuration between the 2 locations are exactly the same, I don’t see why the router is unable to talk to the switch on VLAN2.
Any thoughts?
