Lacking WAN inputs? The Firmware 8.3.0 offers default Virtual WAN support for applicable devices so you can create a virtual WAN on a particular VLAN and continue to enjoy SpeedFusion.
Looking for more WANs?
Use the Virtual WAN Activation License for up to 3 additional virtual WAN inputs, giving your devices more flexibility.
What is the Virtual WAN Activation License?
The Virtual WAN Activation License allows you to create 1 x virtual WAN on a particular VLAN, on either WAN or LAN interface. This means that you can create a virtual WAN on VLAN for a WAN port, or a virtual WAN on VLAN for a LAN port.
Is this the same as WAN as LAN?
No, the Virtual WAN Activation License is not the same as WAN as LAN. WAN as LAN allows users to use a physical WAN port of a device as a LAN port. With a virtual WAN, users are not limited to the physical WAN ports of devices.
However, having a virtual WAN on LAN is limited by the LAN interface bus. This means that the bandwidth range of your virtual WAN is within that of the LAN. For example, if your device’s LAN bus is 1Gbps, the bandwidth of a virtual WAN on LAN is capped at 1Gbps.
Is this the same as a WAN Port Activation License, such as BPL-210-LC-WAN or the Failover License, such as MAX-BR1-MINI-LC-FC?
No, the WAN Port Activation License enables the use of a third existing physical WAN port on the device. This means that the access of WAN is limited to the number of physical WAN ports on a device, while the Virtual WAN Activation License allows users to create a virtual WAN using any of a device’s WAN or LAN ports. Similarly, the Failover License MAX-BR1-MINI-LC-FC only enables Wi-Fi WAN or the use of the device’s LAN port for Ethernet WAN.
Do I need to purchase a Virtual WAN license for a device while it’s on PrimeCare?
No, if a device is on PrimeCare, one Virtual WAN on VLAN license will be included. As long as the device remains in PrimeCare, Virtual VLAN WAN functionality will remain. The free Virtual WAN is only applicable for users without any purchased Virtual WAN licenses.
What if I need more Virtual WAN on the PrimeCare devices? What options are available?
PrimeCare devices have the capability to use a maximum of 3 Virtual WANs. To enable the functionality, you can purchase additional licenses via our online store.
|Product Description|Product SKU||
|Activate 1x Virtual WAN on Prime Care device|LIC-VWAN|
|Activate 2x Virtual WAN on Prime Care device|LIC-2VWAN|
|Activate 3x Virtual WAN on Prime Care device|LIC-3VWAN|
For example, if you want to have two Virtual WANs on your device, you’ll need to purchase the license of LIC-VWAN or LIC-2VWAN, depending on the status of the PrimeCare subscription.
With an active PrimeCare subscription, purchasing LIC-VWAN will add one extra Virtual WAN to the virtual WAN that comes free with PrimeCare, allowing you to have 2 virtual WANs.
Without an active PrimeCare subscription, you will need to purchase LIC-2VWAN to have 2 Virtual WANs.
Which Peplink models can I use this license with?
The Virtual WAN Activation License can only be used with all PrimeCare models (except for UBR LTE and Transit Mini) and some selected models.
Is it ready for use now?
The Virtual WAN Activation License will be ready for use with devices running Firmware 8.3.0. If you would like to purchase and use this license now, a special firmware is required and can be downloaded here.
We’re also glad to discuss the WAN plan with you, such as IP forwarding or PPPoE on the Virtual WAN.
Where can I find this license?
If you are a Peplink partner, you can purchase this license through our online store. After entering your compatible device’s serial number, custom options will be listed on the bottom of the page.
