Video Delay reduce Layer2vpn
Hello we need to make real broadcast to report news from the field
we connect pc—pl380-----sflayer2vpn—Hd4 192.168.1.0/24
the video works great h264 1080p25 bitrate =2000-5000
the video dealy we are getting 1.5sec-2sec
we are looking to decarese the delay up to 50mms
the lines great we are using in wan smothing
can we reduse that latency delay ?
The question becomes what is the source of the 1.5 - 2sec latency?
If you ping across the L2 VPN what latency do you see?
This is Brodcast Video From the Field For reporters from Tvnews
if we can to reduce the 1.5 sec delay video to make real live video better now we get 2.5 sec real live video
can you dhsre with us the video delay you are getting with your tests ?
נשלח מה-iPhone שלי
‫ב-30 במאי 2018, בשעה 13:30, ‏‏Martin Langmaid ‏[email protected] כתב/ה:‬
@amospo
Please open a support ticket for us to check from the devices. The delay can be cause by a lot of influences either application level or network level. This only can be confirm after investigate from the devices.
Make sure you provide the following in the support ticket:
  • Diagnostic report for both B380 & HD4.
  • RA access for the B380 & HD4.
