We have a BR1 MAX LTE-E with a VODAFONE Turkish 4G SIM
We are having toruble with the 4G LTE connection mainily very low speed.
Can any one help if the 4G LTE Turkish network is not performing as due?
We ge speed of few Kb and maximums of 2/3 mb nothing with the expected 40 Mb.
Please help.
Thank in advance.
Hi Dario,
Without further information it impossible to answer your question.
Watt is the reported signal strength, quality and throughput?
Have you tested with a different SIM card and do you get better results?
When you use this SIM in another device in the same location, do you get better speeds?
Please open a support ticket for further diagnosis of the problem.
Erik
Why is 40Mbps expected? Is that achieved using a smartphone? If so which one?
Hi Erik / Martin
Actually it is connected by 3G it seems 4G signal is very poor.
The signal details of the 3G connection follow:
Id de célula
21876
Red
DC-HSDPA+ and HSUPA
Banda de red
WCDMA Band 1 (2100 MHz)
Fuerza de señal
RSSI: -85 dBm
Método de control de salud
SmartCheck
IP detectada por InControl
176.55.185.114
Uso
236.0 kbps (8.0 kbps 228.0 kbps)
Clientes
1
For what I believe it is a very poor signal either, so nothing achievable to the router itself.
Yes we have tested with different sim cards from Vodafone.
The one it is now in, is an turkish Vodafone card.
We have two more cards from Vodafone Spain that does not even get a connection, while the same card in a Iphone works at 15Mbs.
It seems the router does not get a connection with the Spanish Vodafone card wich is working perfectly in Spain.
Spanish cards are full opeartive with 300 Mbs speed achievable.
Yes with an IPAD or Iphone the signal is slightely better 12/15 Mbs (Turkish Vodafone).
Why we expected 40 Mbs, simple HSDPA+ protcol minimums.
Is there any external antenna to improve signal perfomance? P/N?
The system is on boat must be IP67…
Or move the BR1-Max to more exposed placement on Fly top.
Any suggestion is much apreciated.
The tested iPhone/iPad was at the same place as the router?
external anntenna for a boat is alwas a good decision
Where are you in turkey?
