All the routers get the last update firmware 6.2.2 build 1790.
After the upgrade I’m encountering an issue, all the routers doing a reboot every 5 mins.
Anyone else encourage the same issue?
Hi Sharon,
I noticed you have opened ticket. We have feedback to you. Please follow up from there since assigned tech support has better understanding on your problem.
Thank you.
