Greetings,
Would it be possible to activate a MAX BR1 Mini LTEA (Model: MAX-BR1-MINI_LTEA-W-T) with Verizon?
Thank You
Greetings,
Thank You
The LTEA model is not certified on Verizon yet, we are going through the process now. Thanks.
With the MAX BR1 Mini is there another model that is certified to be used? Thank You
Yes the MAX-BR1-MINI-LTE-US-T has been certified for quite some time and there are thousands of them activated on Verizon. Thanks.
Greetings,
Any luck on the certification of the MAX-BR1-MINI_LTEA-W-T on verizon?
Thank You
It is still in the lab undergoing the certification testing, probably another month or so. Thanks
Thank You!
Greetings, just checking back on the matter…I’m really needing this modem to work soon.
It’s getting close, shouldn’t be too much longer…
