Hi dears,
How are you?
We have a very special application on Brazil using MAX TST-DUO with high gain antenna (12 dBi).
So a simple question is: we can use this antenna? What the maximum gain antenna i can use?
Hugs from Brazil !!!
Hi dears,
How are you?
By ignoring the regulations for different country, it should not have any limitation on the antenna gain, provided that the impedance is 50 Ohm.
Thank You
Thanks Sitloongs !!!
