Using a visible SIM in a Max Transit
I am considering adding a Visible SIM to my Max Transit for a backup data plan to use when I have used up all my Verizon’s 100GB data as it slows down to unusable after it hits that mark. I checked the IMEI of my Cat18 Modem and it shows its not compatible on Visible s website. Just curious if that is correct or if it will just work if activated on another compatible device?
Thanks, Bill
If your like every other person on the planet and have an android or iphone, you activate the service via an app while the sim is inserted into your phone. once its active, take the sim out and put it in your Max Transit, your connected!
I was hoping it would be that simple. Was there a settings change to make it work on the max?
