We wanted to be able to route traffic thru the WAN port and the LTE port simultaneously on the BR1.
For example. IP voice calls thru the LTE port while data goes thru the LAN.
Is this possible with the BR1?
The BR1 is a fail-over only device. This means that only a single interface can be actively routing traffic at any given point. If you need load balancing you could look at the Balance 30 LTE or one of the multi-cellular routers we offer. Thanks!
Hi Tim,
Is MAX transit( or duo) can make it? using wan port and LTE port at simultaneously?
Thank you.
Yes, the MAX Transit and DUO support load balancing. Thanks.
