Is there any way to upload a Balance 20 config to a Balance 30?
I am pretty sure you can open up a support ticket. The staff has a tool to convert your config for you if memory serves.
I was in the same situation and went through manually configuring the new router, then I saw some forum posts that resulted in a happy networker. Good luck bud.
Yes - this is right. Do this.
