For some reason I am not able to change wan priorities by dragging them.
This problem just started recently.
Can you please check again ? For the latest changes for the WebUI, you need to point your cursor to the icons below in-order to change the WAN priority.
Hi sitloongs,
It worked !!! Thank you !!!
Before I updated the firmware, I was able to pull them from anywhere
in the tab.
Thank you, thank you, thank you !!!
