I have been running a speedfusion ‘default’ tunnel with Bonding combining Starlink + an LTE connection
Starlink on its own:
LTE on its own:
Bonded tunnel:
Latency at 350? Seems like a lot given the other two. Is that normal?
Speedify in bonding the two put it like this:
Pretty close latency to originals on Speedify. Curious what others are getting latency wise with the SFC tunnels?
Since you didnt mention what device you have I will make an assumption answering this -
Hardware has limits. YOUR hardware has a limit which is preventing it from reaching “line rate”.
Whatever model you have likely has a “Speedfusion throughput of 60Mb”
When a device is hitting its maximum speedfusion throughput it usually has a pegged CPU. That could be the reason you’re seeing increased latency when maxing out speedfusion of your hardware.
What model do you have?
Hi @erickufrin, Ah yes key info: I have the Max BR1 Mini Cat 7.
