Hello all,
New to this forum and i just want to be sure of the types of internet connection used by peplink if its only dsl and cable connections. if it makes use of oc3,satelite,broadband etc?.
Hello all,
The Peplink Balance can make use of any type of Broadband connection, not just cable and DSL. Basically, if it has an Ethernet connection you will be able to use it.
Tim
