Two VPN with Max on the Go x SpeedHub
Hi Guys,
I’ve one Max on the Go with 4 cellular, and I have a doubt about VPNs to SpeedHub.
Is possible do two VPN (2 cellular to VPN A, and others 2 cellular to VPN B), and separate the traffic (VOIP to VPN A, and Date to VPN B)?
VPNs to SpeedHub…
Wilian
If this data will be going to the same location I would recommend using our Multiple Tunnel feature. This can be enabled from the Profile by clicking on the question mark in the black PepVPN Profile in the PepVPN Profile you would like the tunnel setup for. This will allow you to add WAN smoothing or setup outbound policy rules for the VOIP tunnel only.
