I have a Pepwave max Transit. I have two sim Cards installed.
I would like to create two SSID, wifi connections and each connection must be linked to a one sim card.
Is this possible?
Is this possible?
Hi Trenton,
yes this is possible.
Create an extra network with a VLAN ID for the second SSID. Then you can create the second SSID, choose the VLAN ID you’ve created.
After that you have to create an outbound roule and set the algorithm to Enforced an the Source to “IP Network” with the address form your extra LAN
Thats it
Regards
Dennis
