Any temporary bonding activate license key to perform testing on transit duo?
Hi @steivenpoh,
With a new device you should get a free 30 day SpeedFusion Bonding trial if that device supports bonding. To activate it navigate to PepVPN/SpeedFusion section which can be found under Network or Advanced tab and press Try Now button. In which tab PepVPN/SpeedFusion section is located depends on the device. Also, if your Transit Duo is PrimeCare model SpeedFusion Bonding should be enabled by default.
