Do you need a hot failover for this SpeedFusion ? If that is not required, then you can consider to set the WAN in Cold Standby. Hot standby always will having some tunnels connection traffics need to send for the WAN.
May i know the device model that you are having ? I can show you the settings.
@sitloongs
Thank you for your answer. I am using Peplink Ones in the branch-offices and 710s in the HQ.
I would like to test cold-standby, but I think, thats not the best way to go:
The checks of the internet-connection do not produce much traffic. Its the checks of the Speedfusion-tunnels. As I want to have fast failover for the “regular”-connections, I have set up: Link Failure Detection Time - Fast (6s) in the tunnels.
That seems to be my problem…
The fast checks need a lot of traffic - on the active AND on the passive tunnels.
Can this be changed in any way?
@sitloongs
I just changed the setting to “Recommended - 15s”. Now the Traffic-Consumption for 2 Speedfusion-Tunnels (DR) is 1,28 kbit/s which means 428,5MB/month.
