I’m new in this forum and i try to have the most information to choose the best architecture.
What i try to do : make live video encoder thru 5G multisim bonding system like LiveU, haivision, aviwest … and find the most appropriate peplink equipment to do.
The system has to be portative in a backpack, bonded with 5G mobile network.
What i’m thinking : Camera HDMI or SDI output ->> srt encoder (like Zowiebox) -->> Redundant 5G modem ->> srt relay in datacenter ->> Video switcher
I see a lot of different peplink model to do that, but it is difficult to identify the best and with what optionnal accessories (power, antenna…) for a transportable system in a backpack.
If anyone has already made this kind of system, thank to him to share how he did.
Thanks ! i didn’t see that backpack exists from peplink.
What about power ? battery is included?
What about antenna ? You keep the original or replace them by external like “Antenna MAX” ?
The backpack is from a partner in the US West networks. He is using v-mount battery in the bag. His bag uses the included antennas. I’ve seen others use the slim antenna Slim Antenna Series | Peplink
Hello @CEDRIC_LUCAS,
Welcome to the Peplink Community Forum. What part of the world are you based in?
@MartinLangmaid’s recommendation is a great starting point if you want a solution that matches your requirements. There are a few extra considerations around how best to utilise the Peplink SpeedFusion technology for the solution, and there may be additional costs.
I would highly recommend that you reach out to your local Certified Peplink Partner or via Peplink’s online enquiry form to request to be put in touch with a suitable partner.
Have a good day,
Marcus
