I’m trying to telnet from a network on a MAX that’s connected via SpeedFusion to a device connected to another MAX. Speedfusion VPN’s are setup through our Peplink Balance 380
Site 0:
Peplink Balance 380 gateway 192.168.0.1
all speedfusion connections are in the same profile
Site 1:
MAX HD2 gateway 192.168.1.1
Telnet client 192.168.1.2
Site 2:
MAX BR1 Pro gateway 192.168.2.1
Telnet host/destination 192.168.2.4
Every attempt to connect via telnet results in:
“Could not open connection to the host, on port ####: Connect failed”
or “timed out” using another client
Pinging between these devices works. Accessing/operating other devices across the speedfusion VPN works.
Anything I can do to direct/allow telnet traffic or prevent the telnet connection from timing out?
If Telnet is possible to the target device on the same site and you can ping target device from local device then I would suspect a firewall or Telnet service configuration issue that only allows connections from local network segment.
To prove this, on both Peplink devices navigate to the support.cgi page and start a network capture, then try and telnet to the target device. Then check to see what the telnet session flow is.
