Surf Soho Mk3 running 7.0 firmware. I am looking to connect my router to a VPN provider (using IPSec will work but I would prefer OpenVPN). The documentation shows IPSec should be an option on the Advanced page but am not seeing it. I have wifi devices on my network which I would like to run through VPN which don’t have the ability to install VPN software, therefore need to connect the router to my VPN provider. Is this available for the Surf Soho and can you provide guidance?
The SOHO itself does not support IPSec tunnels but you can try changing your WAN connection method to L2TP if they support that.
Thanks.
