Surf Soho Firewall event reports
Does the Surf Soho report on Intrusion Detection and DoS Prevention threats?
Other routers I have had in the past have all shown regular external threats that have been rejected by the firewall.
It maybe coincidence but having had the Surf Soho for a few weeks, no Intrusion Detection and DoS Prevention threats have appeared in the Status Event log.
Yes, this is supported.
You can find this at the firewall settings.
Please refer to page 70 in the Surf SOHO manual for more information.
Thanks for your reply.
I may have missed the option but it seems that the option to log only exists on new rules not on the Intrusion Detection or DoS Prevention.
Is this option somewhere else?
Thanks for your help.
Peter
