We are preparing to deploy approx. 200 BR1 Pro’s in vehicles.
As an example.
If I have an incident that requires multiple vehicles within a close proximity of other at a location all within the same 2-3 square blocks of each other.
It is a bit difficult to get a clear view of the scene from the map due to the oversized, un-scalable Map Markers that are nearly stacked upon each other.
Even if I turn off the labels its difficult to get an understanding of the situation.
Also:
Could we get the ability to add more icons and or add our own map markers??
Its been awhile since this was posted. Would be a great idea to use our own or have more map markers
- We will add an option to change the markers to half size in the next release.
- We will also allow the support of uploading custom markers at group and organization levels. However, we will put this feature in Q2 2023.
@Michael
I love the half size option that was released. Nice work all.
Do you know when the “custom markers” will be available?
We are still aiming at Q2 2023. Stay tuned.
