Subnet Selection Mode on Cellular WAN
Again, Force/31 cannot help me because it does not allow me to type in my own gateway and subnet, such as 166.xxx.yyy.1 and 255.255.255.0. Force/31 still chooses the gateway and subnet for me.
Below is a diagram. I believe the reason I cannot communicate between the routers is that the WAN IP address on the other router just happens to be the same as the WAN gateway on the Pepwave router. There is a conflict. I cannot change the WAN IP addresses, but I should be able to change the gateway and subnet mask.
Perhaps I should start a new thread for this issue because the Subnet Selection Mode and Force/31 are not solutions.
@bcurley
Can you open a ticket regarding this case of yours so our team can check on the behaviour between the 2 devices.
Refer here for the steps to opening a ticket. Thanks.
Its 2021, was this issue ever resolved? Can’t go back to 6.3 firmware
Is there a way to set a custom subnet mask and default gateway on the Cellular WAN interface?
My use case for this is for clients to talk with each other within the same APN in private cellular deployment and not skip IPs being assigned to clients. Thus, a client would be assigned the gateway address of another cellular device and they can not talk with each other.
