I need to stream hd video from a remote location, my cdn is dcast, what peplink modems do require to successfully stream a very smooth feed and what would my min required 3G speed be per sim be. I want to bond the 3G connection as well
You will need to use the MAX mobile router out in the field with your encoder solution and then use a Peplink Balance 210 or higher at your office or datacenter with your decoder solution. The quality of the stream completely depends on the bandwidth available from the carriers…
Hope this helps.
