Hi Support,
I have an ISP with multiple static IP addresses. I’m currently using one IP: 210.123.123.123. I also have 210.123.123.124 to 126. If 210.123.123.123 gets blocked, what methods can I use to make the other IPs act as backups for internet access?
if your primary IP stops working it is almost certain the others won’t work either as it will be a routing issue by your provider to that prefix.
If you are talking about the ip being blacklisted externally then you would need to manually swap to one of the other IP’s to be the primary.
Hi Sir,
I tried peplink restful API to monitor wan status , after monitor wan status is down API can change wan ip address , the process working good.
