eibyer
February 6, 2019, 6:19am
1
We have an existing B20 with an IP of 192.168.0.1 and would like to reach device(s) on 192.168.88.0/24.
The WAN port of the mikrotik router is assigned 192.168.0.14 and is connected to one of the LAN port of the B20.
I tried the suggestion from the other threads of creating an outbound policy but that didn’t work for me.
Thanks for any suggestions.
hi eibyer, if the network 192.168.88.0/24 is behind of mikrotik, you need to add a static route on balance where 192.168.88.0/24 via 192.168.0.14 .
then u need a default route on mikrotik, with gateway 192.168.0.1 .
Now if you connect your pc on lan port of Balance , you should be able to contact a device on that network .
eibyer
February 6, 2019, 7:01am
5
Strange I can ping devices on 192.168.0.0 from 192.168.88.0 but not the reverse. I’m new to the mikrotik router.
you can reach from peplink the ip address of mikrotik of this lan 192.168.88.0 ?
eibyer
February 6, 2019, 7:07am
7
I can’t reach 192.168.88.0 from peplink.
there is a nat or firewall enable on mikrotic ?
eibyer
February 6, 2019, 7:10am
9
RouterOS is too complicated for what I’m trying to do, let me switch to a different router and report back. Thanks for your assistance!
asimula
February 6, 2019, 7:14am
10
Ok, i don’t know a RouterOS Mikrotic .
good luck
eibyer
February 6, 2019, 7:57am
11
Grr, still can’t get to 192.168.88.0 from peplink. I must be missing something simple
asimula
February 6, 2019, 8:12am
12
the problem is on mikrotic, check if you have enable a nat or firewall rules on this device .
eibyer
February 6, 2019, 8:15am
13
I actually switched over to another router, this one is a TP-Link Archer C7. (I need to modify the thread title) I turned off the firewall in the C7 but still no go. I can still reach 192.168.0.0 from with the the C7 though.
asimula
February 6, 2019, 8:20am
14
you set the same ip address of mikrotic ?
do you have a nat enable on this router ?
eibyer
February 6, 2019, 8:23am
15
Yes, same IP settings from mikrotik. This is what the NAT settings of the C7 looks like.
eibyer
February 6, 2019, 9:00am
16
I found the NAT settings buried deep in the system tools > system parameters. It’s all working now
Thank you!
