starlink & max duo setup
I have a Starlink which is running great (Arizona) and over the weekend, using the Starlink Ethernet Adapter, plugged it into the WAN port of my Pepwave MAX Transit Duo. When connecting to Starlink via Pepwave, it dropped in speed as well as connection became spotty.
What are the settings within the Wan Connection Status I need to adjust? Do I have other settings elsewhere I should look at? What about within the Starlink admin, anything to adjust there?
Hi, Daniel.
How are you?
Please… take a look at
Starlink app fix - #3 .
This link help me to undestanding how Starlink works for his management. “2 - Input the Management IP:” also take a look at
https://forum.peplink.com/t/starlink-and-max-transit-duo-slower-than-starlink-by-itself/627e81097e72a52ad33839b4/63
" I have been working with Starlink on this and it appears to be an issue with the way the two devices negotiate the link when set to “Auto” or “1gb”
So far the work around for this issue is to set the link speed on the PepWave to “100M” or use an intermediate bridging device like a switch. Granted 100M will slow your download speed a bit when using starlink. "
